another_jim wrote:It's hard enough putting good numbers on bean temperature; ET is really tough. The profile JimG posted would translate to about 15degrees higher on bean temepratures and who know how much higher on ET. On the other hand, the profiles Rafael is posting using the same roaster I am shows higher temperatures all round
So all the advice is more or less qualitative.
I think a collective project to work out a method for calibrating temperature measurements across roasting systems might be fun -- maybe impossible, but definitely interesting.
another_jim wrote:The first crack makes one good calibration point, but I think a second calibration point is also required. The measured temperature is a combination of room temperature, the roaster's heat source temperature, and the bean temperature. So, it'll be like calibrating anything, we'll need a two readings to get the span and zero.
I think that 1st crack is an obvious 1st measurement to use as will be fairly profile resistant. It's finding a 2nd point of reference that will be tricky as something like 2nd crack or other points will be more effected by the profile for comparison.
