Please remember that there are online reports of people doing loads that go up to 400g, with many talking about the 250-300g range, and they're all happy. I've done 300g & 225g myself earlier, when I was looking at good taste but not much else. With 150g, but more importantly with more experience, I was able to get better roasts. But all that doesn't matter here, so, let's - for this part of the discovery exercise - discuss only the mechanics. Again:
- Element is on the left side of the roaster, taking the space between ~8 O'clock & ~10 O'clock.
- With 300g, I'd estimate that beans got as close as 3cm to the element, IIRC.
- With 225g, I'd estimate that beans got as close as 5cm to the element, again IIRC.
- Now, with 113g, beans never passed the 6:30 O'clock mark, so I'm estimating 9-10cm away from element.
Again, everytime you get closer to the element, the higher the MET; and because we can't measure MET, we give this statement a lot of importance.
The other part is extended pre-heat. The idea here is simple too, give the roaster time to stabilize as to not have too much of a heat differential between different parts of the roaster and, then, need to compensate by using high heat. I have not got to this yet, but it sure sounds good till I get a chance to verify it.
Now, back to the 113g batch:
- same bean & pre-heat strategy as other batches.
- beans never passed the 6:30 O'clock mark in the drum.
- beans didn't cover the HT builtin probe or enough of my BT probe(but I'm inclined to trust my BT reading).
- never gone beyond P=6.
- no burnt smell, could be my nose or amount of beans, have to verify thru taste.
I haven't given the 225g batch or this 113g batch the siphon treatment yet; will hopefully do and report back.
Next batch will be 113g with the same Brazil again, but with a lower charge temp; after an extended pre-heat, of course
