Bella XJ-101 1kg Roaster
- ciel-007
After cracking through several hundred pounds of greens with my modified Hottop, I feel ready to graduate to a larger roaster for home use.
Earlier today, I was presented with an opportunity to buy a used BellaTaiwan XJ-101 roaster. It is about 5 years old and is propane fired. As far as I can tell, this particular model is virtually identical to the Yang Chia 801N, and Feima 801N roasters.
I am wondering if any of you might be in a position to talk about your roasting experiences with a BellaTW XJ-101, or perhaps share some noteworthy information about the above companies or roaster models.
Your feedback would be most appreciated in helping me reach a decision. Fern
- hankua
I've been roasting on an 800n for two years; both machines are made by Yang-Chia Machine Works in Taichung Taiwan. If you get a deal?
BUY IT!
BUY IT!
As Hank already mentioned, GET IT! Like Hank, I roast with a Yang Chia 800n/mini 500.
Yang Chia (literally means Yang Family Machine Works) manufactures coffee related stuff with brand name Feima. For people who don't speak Chinese, it may sound like FAEMA, but in fact, due to ignorance of language. Feima means Flying Horse (飛馬).
Yang Chia roasters are used in roasting competitions in Taiwan, sponsored by the distributor BellaTaiwan. Numerous coffees rated over 95 points on CoffeeReview were roasted with this particular roaster.
- ciel-007 (original poster)
Your picture of the control panel is rather blurry, but if it is similar to other Yang Chia 801N roasters:
Top row: PID for temperature readout/ Rotation Speed knob/ Drum motor toggle switch/ Ignition
Bottom row: Alarm toggle switch/ Reset/ Main Power/ Roast Fan/ Cooling Fan/ Stirrer
The 801N has graduated fan control. Some will modify the exhaust analog gauge to a type K thermocouple.
The other day I was looking at these guys racking up 90+ scores.chang00 wrote: Numerous coffees rated over 95 points on CoffeeReview were roasted with this particular roaster.
http://www.papalins.com/
The photo of their roaster looks like one of these Yang Chia or Feima. Could anyone care to ID?
- TomC
It is, and I think it's a good selling card that promotes this roaster. It was the same price as the roaster I bought, but they couldn't make a larger tryer with the drum design. I also worried about support for any mechanical issues, but they're apparently so well built that it's never really been an issue.
Papa Lin roasts with a Mini 500 distributed by BellaTaiwan (aka Yang Chia 800N) with perforated drum.
- hankua
Fern, we have an informal support group here although there have been few problems.
Just in case you score that awesome roaster.
I'm a little jealous, used ones are quite rare.
Henry, thank you for explaining the control panel switches - that's much appreciated!chang00 wrote: Top row: PID for temperature readout/ Rotation Speed knob/ Drum motor toggle switch/ Ignition
-Is it correct to assume that the PID provides BMT?
-How useful is the variable drum rotation speed function?
-Can you explain the alarm function?
I've attached a few more photos of the Bella XJ-101.
Fern
