Beans = Ethiopia DH Haile Selassie Sidamo from Sweet Marias
room temp = 71F
load 200 grams
charge temp = 500F
MET = 560F
5:58 390F 1C
(at 400F turn off power to SSR. MET starts to drop. Then MET meets BT at 430F)
8:27 429F END
Differences: I was force to turned off the SSR power at BT 400F, otherwise the roast would have ended too early.
Red line = BT
Green line = Exhaust T at handle
Purple line = BT - ExhT
(I forgot to turn off the data logger at the end of the roast, so you see a long decline of T at the end.)
Preliminary chewing results: The results are so so because there is a little char flavor. At first byte, I sense a char shadow on some of the beans, but then the flavor changes in to something else. Some beans have some initial char flavor. The total flavor is very different from previous roast (charge temp of 420F no char flavor). I am not able to say how this will transform in the cup. Maybe a charge of 500F is too much but 420F is OK.
Cheers
Cheers
