rama wrote:I tried my hand at roasting a Brazil again- first time since the homeroasting competition- and again had some charring and tipping despite a lower drop-in temperature and a lower ET (although less than before). It ended up being about a 17 minute roast. Anything longer, and I fear "baking" the beans.
How much fan are you using & where? I eliminated most of my charring issues(didn't have tipping problems) by not using the fan at all after a short period during the drying phase. Normal drop in is 325*-350*F ET & typical turn around temp is 190*-202*BT. I'm using the same 227g load I've always used & getting what I consider to be very nice results. I'm also using a 22amp Variac to help speed up or slow down the roast as needed & finding it to be a very handy tool despite what I've read about the Hottop not needing it.
I've roasted 3 different Brazils for espresso recently, all with a 4 minute+ stretch & all ending in the 14 minute range. The only one I've sampled so far is the Moreninha Formosa Raisin M/L(Feb 09) which I took just into the beginning of 2C (FC+). After 6 days rest I am getting very creamy shots with nut & strong chocolate flavors.
I picked up a couple used drums recently & based on a suggestion from Ed (Farmroast) I'm going to try adding taller stirring fins. Hopefully these will lift the beans high enough that they fall through the hot air in the drum instead of just rolling on the surface. If successful this should help to reduce charring with larger (227g+) loads.
