Artisan time axis scale
- Almico
Is there any way to stop the time axis scale from going to 1 minute when I reset a roast? I like it set at 15, but when I restart it defaults back to 1 minute total time.
- zeece
- MaKoMo
The "Initial Max" set the largest x-axis value displayed initially in the graph after reset.
The "Min" and "Max" just display the actual x-axis range that is displayed in the graph.
If "Lock Max" is ticked, Artisan will not extend the x-axis if the actual recording time exceeds the x-axis max during recording.
If "Lock" is ticked each profile loaded will display the x-axis range specified by the actual "Min" and "Max" values. This can be useful if one wants to compare profiles on the same x-scale.
LMWDP #360, https://artisan-scope.org
- Almico (original poster)
That did it. I didn't have the axis locked...thanks!!
- JK
I had the same issue and I forget what causes it..
I think if you let the roast run over max time.
Mine still does it now and then.. Just keep resetting it and it will stick one of these times
I'm on a Mission from God!
- JK
Artisan is running fine in Windows 10..
- MaKoMo
Excellent news! Thanks for testing.
