Artisan statistics question [SOLVED]
- johnny4lsu
I can't answer your question, but why do your probes read so low?
- johnny4lsu (original poster)
Man I really don't know...I HAVE to get new ones...This is the style that I have..http://www.omega.com/pptst/XCIB.html XCIB-K-1-5-3 K Type...Grounded Welded Junction
I'm certainly open to help in remedying the problem...They've been like this from the start
- TomC
Have you recently taken them out and checked them with an ice slurry and boiling water to verify this? I agree that they've been reading low, we've already discussed that part. Hopefully you can start scratching off items on the checklist of what could be wrong. It could be something on the software side (which I couldn't help fix if my life depended on it).
And it's entirely a matter of personal preference, but I thought I'd share one point, that font you've chosen is extremely hard to read on these small images here. Especially on longer roasts or when many events are highlighted. Without stepping on your toes, you may want to consider a more standard font. One of your graphs were almost unreadable.
Haha...Well, I had no clue that it's possible to change the font..I just assumed that's what it defaulted to...Gonna check that out now...I'll check out your other suggestions...Thanks
ETA: Font is now correct..Not sure how or when that was changed.
You can also change the axes displayed after the roast finishes: Config / Axes. You should set the minimum at 0:00, and max about 1 minute after the drop.
LMWDP #556
Life is too short to drink bad wine - or bad coffee
It's most likely not the cause but I would check the thermocouple type setting on your digital meter. I dont know what would give you a approx 63degF offset at FC (usually around 370F for Ethiopia on my Hottop). If it's the wrong thermocouple type setting, the graph would look a bit skewed too.
If that's not it, and if you think the scaling on the Y axis looks ok, that the temp error is just an offset, I wonder if Artisan would let you program a pre-defined offset just so the graph gets shifted up correctly.
Very interesting... I use the amprobe and didn't even consider an option to change tC type. Will check when I get home.. Thanks
