Artisan Glitches
This is a new one to me! Had my best roast with this coffee, and now cannot make sense of it because Artisan glitched out when I stopped monitoring.
Any ideas on how to fix it? (Notice the times.)
Also, in the first minute or so of a roast, I always get a sort of double vision of the graph going on. Usually clears up after that. Not a huge issue; definitely not as big of an issue as what you're seeing in the image!
- drgary
David,
Can you provide more information on your computer, your operating system, the device you use to transfer data from your thermocouples to your computer? I ask this because there's still a question left open about Artisan's compatibility with the El Capitan OS on a Mac.
LMWDP#308
LMWDP#308
Looks like the "charge" event got recorded at the same time as "drop". Any time during, or after the roast, you can click on a time in the chart and set the charge time, as well as other events. That should have fixed it. You might still be able to do that now.TerminusCoffee wrote:This is a new one to me! Had my best roast with this coffee, and now cannot make sense of it because Artisan glitched out when I stopped monitoring.
As for the "double vision", I bet you are running Artisan 0.9.8. I've seen the same thing, and I think it's a bug in 0.9.8. I went back to 0.9.7 and have not seen that problem.
My bad! I'm used to posting in the Huky Forums!drgary wrote:David,
Huky 500 + Phidgets 1048
Mac OS X El Capitan 10.11.2
This is the first issue I've had like this. Can it be edited somehow?
FIXED: If you zoom in (or are just really accurate) on the point that you actually charged at, and it fixes the graph! Wheee!
Exactly!robmatic wrote:Looks like the "charge" event got recorded at the same time as "drop". Any time during, or after the roast, you can click on a time in the chart and set the charge time, as well as other events. That should have fixed it. You might still be able to do that now.
Got a link for .9.7?
Thanks so much.
- MaKoMo
The double curve drawing was resolved in one if the last 0.9.8 builds. All version are fully compatible with the larest OS X 10.11. This was confirmed a while ago.
LMWDP #360, https://artisan-scope.org
- MaKoMo
Did you run into problems on OS X10.11?
- SAS
- Supporter ❤
I don't know if anyone has advised you on this, but you must do a factory reset from Artisan after installing or reinstalling the Artisan software.
Save all your settings first so you can reload them afterward then...
Select: Help; Factory Reset.
LMWDP #280
Running on fumes.
Running on fumes.
