Artisan 9.8.5 for Windows
- LDT
The second time I used this version and after changing the color of the plot for fan speed, my LCD for Delta BT has vanished. Actually it's there, but the display is blank. Also the plot of the delta bean temp is is OK, just no data displayed in the LCD. I've gone thru the many screens of information but can't remember how to get the Delta BT to display properly. Any suggestions?
- JK
Did you check to see if numbers and background color are both set to same color?
I'm on a Mission from God!
May get some answers on HukyForum under "Where are the default Buttons" asked yesterday re Artisan
http://www.hukyforum.com/index.php/topi ... ml#msg6216
- Arpi
There is a setting for the deltaBT LCD in the menu: Tools/ Extras/ Graph/ LCDs
Cheers
Cheers
- LDT (original poster)
Thanks to all who replied. I'll try to solve this tonight after work.
Solved my problem with an reinstall of Artisan 9.8.6 and making sure the Delta BT LCD outline and number readout were set to different and visible colors. Thanks.
