endlesscycles wrote: how should the first crack occur to maximize aroma? I've been testing roasts side by side whereby all other things equal
In the Illy book, they suggest that the aroma created is proportional to the pressure build up. An the pressure build up is proportional to the rate of change of BT up to a limit.
They say:
"a build up of pressure inside the bean is important for the generation of sufficient aroma" (page 184).
A faster rate during the First Crack will give you a louder pop (higher pressure). And a lower rate will give you a quieter pop (lower pressure).
They say:
"temperature control of the heating gas, permitting not only temperature profiles with moderate differences, but also a sufficient pressure build up inside the bean, has to be the objective of roasting"
To me, "sufficient pressure build up inside the bean" translates in to a BT rate of change to some degree.
Cheers
