by another_jim on Sun Nov 29, 2009 11:52 pm
The bean temperature sensor at th time the beans are dropped in.
The M3 instructions, as far as I can tell, recommend a 160C to 175C drop-in (320F to 347F). This will give you about 10 to 12 minutes to get to the first crack. I've tried 190C to 200C drop-ins, which got me 8 to 9 minutes to the first crack. These times based on roughly the same heat and air settings after the drop-in.
The info I read on both larger drum and sample roasters seemed to indicate that the drop-in was more important for speed to the first crack than heat settings during the roast. I find this odd, but it seems that competent roasters have the drum at close to its maximum temperature throughout the roast, so the air temperatures at the roast's start may be the one big variable.
