by another_jim on Fri Sep 25, 2009 4:16 pm
You can fabricate a vent from dryer duct, a small fan, like those used in computers or in small exhaust ducts and a thin board. Cut the board so it fits into the opened window like an air conditioner, and put a hole in it to mount the fan. Then attach the dryer duct from the roaster to the fan. That will pull out most of the smoke.
If you have a range hood that exhausts or uses carbon filters, it will also work, especially if you build a skirt for it that hangs down and encloses the roaster.
All this stuff (roaster, coolers, controls, ducts) can be a bit of a Pita to mount and unmount. The most convenient solution is a permanent roasting station. If you are a space challenged city dweller, a cart or large tray which holds all the stuff you need for quick set up and break down is still a lot better than having all the items separate in a closet.
