by scrutinizer on Fri Aug 26, 2011 2:15 pm
JY,
I bought an Alp in 2002, it worked as designed for 11 months and suddenly died w/o warning. Swissmar honored the 12 mo warranty and shipped me a new unit and that one lasted for 7 years of weekly roasting. The overwhelming feedback from the user community is mostly negative but for whatever reason I liked my unit and it performed well as a first roaster (roasted 8 oz batches, could route exhaust through a dryer hose to outside, dumps beans into cup, minimal attention required, coffee tasted pretty good though may not win any contests). None of my roasts ever looked so uneven as the prior post although I'm not questioning the validity of the picture. I will say the picture looks alot like the funky beans that are left behind in the drum after a roast that, as indicated by the instructions, should be tossed as they didn't have enough mass to spin out into the cup during the "dump". A swissmar tech had also indicated the unit needed to be kept clean in order to keep it alive and functioning as intended that may explain the longevity and performance of the 2nd unit (first unit wasn't cleaned regularly). My voltage was likely quite low over the years and its possible that it helped tone down the scorching that other users had complained about. I also commonly roasted blends that didn't vary much in composition and roasted to a "vienna" degree of roast. These preferences probably contributed to consistency in results, however, any time I did single orgin, it worked fine.
My Alp seemed to be getting tired about a year ago so it was replaced w/ a Behmor. I can get better roasts w/ the Behmor with an additional variac and voltmeter after spending a substantial amount of time figuring out how to work within the constraints of that roaster, however, the simplicity of the Alp has its merits for someone starting out who wants fresh coffee w/o embarking on a research project (just push start...wait...listen...push stop). As already stated, it does not compete with roasters costing much more but I'm not sure we should be expecting low cost equipment to perform at that level anyway...as usual...you get what you pay for and if you don't want to pay much then there may be some additional challenges.
I am aware they made various changes to the design over the years and these changes may have degraded performance to the point of "no performance". Quality control was apparently quite variable causing some units to work fine and others to be mired in problems or die early. If I could have purchased my exact unit for $300 last year I probably would have, but the last run seemed to be too iffy whether they would work or not so I looked elsewhere.
If the unit you are looking at was late production then there is a reasonable possibility that it won't work but, then again, it just might work, and so it depends on how much you value the money spent vs the risk/reward (you may be buying a "boat anchor" out of the box or an inexpensive and potentially adequate home roaster for almost nothing that could last years). If you do decide to buy, you can check the web for tips on how to adjust the temperature (via a pot on the board, if I recall correctly). It seems like some folks needed to do that with newer units to get the performance they were seeking. Good luck.
Pat
