CoffeeCON 2012: It's free to attend. It's free to drink. It's going to be awesome.
Air-roasting very light
Postby noah on Sat Feb 27, 2010 8:01 pm
Real city roasts that scream with flavor are the one roast that I am struggling the most to achieve. I am perhaps confused about something. When roasting very light, should one still try to achieve the full amount of development time from the onset of first crack to the end of first crack, or does roasting very light simply imply that you proceed "normally" to the end of the first crack and then stop regardless of time (which would certainly stop well before the normal three minutes of first crack to the end of the roast cycle)?
Thanks
LMWDP #263
noah
Postby Brewking on Sat Feb 27, 2010 8:42 pm
Hi Noah, I'm not an expert, nor do I know what roaster you are roasting on, but City roasts still need to complete first crack all the way and then progress a little after that. Beware with City roasts on a home roaster, especially a popcorn popper, because in my experience these roasts are under roasted and unbalanced. Very acidic and unappealing. Coffee still screams with flavour when roasted up until the first few snaps of 2nd crack and then cooled rapidly.
I hope this helps.
Brewking
Postby another_jim on Sat Feb 27, 2010 11:02 pm
You want to spend at least three minutes, but probably no more than five minutes, from the start of the first crack to the end of the roast. This is even truer of light roasts than dark roasts. So slow down when the first crack starts for light roasts. If you are roasting dark, you will still have a ways to go, so you can keep up some roast speed.
another_jim
Postby seedlings on Mon Mar 01, 2010 2:12 pm
If you're using an un-modified popper, this will be very difficult to control... especially in the important drying phase. I've had success spending 5 to 7 minutes at moderate heat, taking the beans slowly up to yellow/drying (beans up to 300F), then using a higher heat up until the aroma gets a little sweeter right before first crack, then returning to a moderate heat throughout first crack. Dump the roast just as soon as you're convinced first crack has completed, then cool immediately!
CHAD
seedlings
Postby Randy G. on Mon Mar 01, 2010 5:00 pm
Without knowing the details on "how modified" your modified air roaster is, nor how controllable it is, I offer this: Most popper roasters are very fast, particularly in the critical early drying phase. If you can hold the environmental temperature to around 300-320 degrees until the beans begin to turn tan after the green phase, and slow it down enough to get first crack to happen no sooner than about 9 minutes along, it will go a long way towards allowing the beans to develop better later in the roast.
Most air roasters finish so fast that allowing the drying phase to occur before dropping the green flag and running the race to second crack is a big help.
Espresso! My Espresso!
Randy G.
Return to Home Roasting
