I bought 10' of copper tube. I used an iron pipe with wrapped around masking tape and a vise to obtain the shape I needed. It works as a heat exchanger.
Then I bended the end so that it makes it to the air intake hole
and wrapped the copper with insulation
This is the result. The difference is in the mid phase to 1C from dry phase to finish phase. The temperature of the mass of the beans climbs now much faster to 1C by using convection. That's the only difference from before. Compare the slopes of BT and MET in the pic bellow
compare that with my performance before
With the new mod, my delta BT is very high up to the 400Fs where I need to bring down the power. I think I can do now much heavier loads and keep good times.
The air input is from a vacuum cleaner in reverse mod. It blows air instead. I use this vacuum cleaner:
http://www.shopvac.com/vacs/detail.asp?...x&StoreID=
but a less powerfull vacuum would be needed for best performance. I brought down the output of the vacuum cleaner with a router speed control. There is an accessory that brings down the hole size and fits the hose perfect.
PS: next weekend I'll plug the input hole so that the roaster will only use heated air.
Cheers
