ZR-71 grinder prototype - Page 20
- FotonDrv
Probably so.day wrote:I would imagine that this might vary quite a bit depending on the grind setting?
- dsc (original poster)
In manual ie. by hand, as quickly as you can press the button, in automatic it's a bit slower, but roughly twice a second or so. It does mix everything in the chute, but you have to remember that any static will wreck things quite badly, pulling most smaller particles and dispensing them last.neutro wrote:How fast can the grind settings be changed? Can the grinder "pulse" its settings many times while grinding a double dose? If so it might mix in the chute; or create many layers of alternating density. Might be better than a linear profile.
T.
Then a pulsating electric field should mix particles of different size quite well
It would make a hell of a feature name too. "Does YOUR grinder have a pulsating field chute?".
That being said, I always wondered if having a larger grind distribution, but not too wide, would provide better packing of the puck. I have no idea what the results would be in the cup though, and in the end, that's what is really important.
- shadowfax
I'm afraid I can't grind that, Dave.
Nicholas Lundgaard
Great reference.
- bostonbuzz
It's probably easier to have no weight on the beans (bird feeder principle) than a constant weight.
LMWDP #353
I've had better results with a weight on rather than no weight at all. I can always tighten the grind automatically during the end phase of the grind to compensate for any weight changes.
T.
T.
