by napierzaza on Fri Apr 01, 2011 10:29 am
I bought a used Rocky and after a bit of time I got frustrated because I was getting a huge amount of cracked coffee that spurted all over the place. It was pretty frustrating to be certain. The grinder itself also got incredibly packed with coffee grounds and I had to open it up.
Basically the grind was not good enough so I had to tight the setting down to practically zero. So basically everything was been extruded through the grinder blades instead of broken up evenly. Which led to issues with everything getting impacted inside the grinder.
All of those things cleared up after I got new burrs.
I think with sharp burrs the coffee gets kind of pulled through as it gets sequentially smaller and out the other side. But with dull ones you need a lot more push from the beans behind it to push it into the teeth and it just doesn't work the same way. Besides, go on ebay, they are cheap.
