Title says it all. I have a RoburE and want to put the doser on it for single dosing. I know I have to keep the electronic lid but I would like to remove the funnel and replace it with a Mini doser that I have available.
HB wrote:No, the Robur doser is taller than the Mini's.
Ok. Will the internals fit inside the Robur doser body? I ordered the body from EPNW but they don't specify what internal parts fit. I have a Mini doser and can cannibalize it.
The doser lids - if I recall correctly - are interchangeable. That means same diameter. It's likely that you could mount it although the dimension of the rectangular opening where grounds exit chute into doser may be slightly different. A bigger problem will be the height difference *If* it fits you'll still end up with an open space on the body of the grinder - below the doser - that would need to be covered.
I posted my results in a different thread and forgot this thread was here but the Mini doser would require too much modification and all I need to have the correct doser is the housing. I bought one from EPNW and it arrived yesterday and I put it all together last night. The internals are the same except the clear plastic cylinder which still fits but doesn't go as high up on the inside.
