RapidCoffee wrote:The problem is, any retrofit to a dosered grinder will not be as elegant as a grinder that is designed to be doserless from the ground up. Baratza and Mahlkoenig, in particular, are doing very well along these lines. Mazzer, unfortunately, is not.
I believe that Krups led the way with this design, silly as that sounds. My first burr grinder was (what, a 20mm flat burr?) Pictured here (OK, this is an artists rendition of its more famous cousin...):
I've supered a not-accurate-but-really-indicative picture of a small rotor approximately where the real motor lives, and an artist's rendition of what the bean hopper looks like Say what you will 'bout his li'l guy, but he was remarkably portable, remarkable in consistency, lasted forever, FP to Turkish, could stall Silvia, and never stored more'n about a tenth of a gram of ground coffee.
Straight through design, from the bean to the funnel shaped grounds hopper.
