by Randy G. on Thu Feb 12, 2009 1:25 pm
In the 6 or so years I had my Rocky I changed the burrs twice, about every two to three years or so. I estimate that about 75 pounds or so went through each set, but I never kept track. It could have been less... or more. I have never read what the actual rating on those burrs is, but based on my experience it is probalby no more than about 75 pounds, tops. With each time I changed the burrs the performance of the grinder was noticeably improved with each change. Why? For one set, some of the coffee I ground was Yemen, and the Yemen concrete drying pads are (were) disintegrating so bits of concrete did get ground at times. For more of that same coffee I would gladly sacrifice another set of burrs. It could also be a factor of the qualtiy of the burrs and the hardness of the alloy used or its heat treating (all sets were genuine Rancilio burrs). I don't know.
The bottom line is that your burrs are at a point that you have little to lose by changing them. Worst case is that you see no difference, and just keep the old ones as the spares. best case is that you have a new grinder which you won't have to worry about for another 6 years or so.
