Unbelievable.
If I want to say something, I will say it myself.
I wasn't missing that. Nor putting words in your mouth.
By your own admission you have done only that one comparison (you will be stunned to hear I haven't forgotten). With a very bright bean as you have stated. Moreover, with a bright bean dosed quite inappropriately by your own description:
The test doubles were about 1.5 oz from 18-20g (EDIT - each pair was weighed to match) in a "standard" ridgeless double basket. During the dialing-in process we tried doses ranging from 18g to 21g and ran shots from 1 oz to 2 oz (with flow rates from normale to ristretto).
You acknowledged that the extractions you were getting did not allow any distinctions other than - again to quote, to avoid unnecessary consequential rhetoric:
The tasters had difficulty distinguishing any differences in the cup.
The judging was made based on least offensive...but all the test shots were sinkers.
I feel badly for the tasters, it was a painful task
Nicholas put this in pespective as the
least presence of the defect of unpalatable sourness
I'm afraid that's quite simply not a valid comparison.
If it is the only one you have done I can understand your being "skeptical".
On the other hand I am not making any outrageous claims. I have quite amazingly "discovered" that these grinders work best the way they have been designed to work.
There is nothing to be "skeptical" about there. I am hardly claiming to have invented a new wheel.
Rather there is plenty to be "skeptical" about regarding the assumption that single dosing is going to yield favourably comparable results, being entirely outside the design parameters.
So the bottom line is do I think using the grinders as designed gets the best results, purging before each "new" shot? Definitely!
Do I think single dosing works? Of course it does!
Do I think it gives the same results? No!
Do I think it is advisable? I think you pays your money and you takes your choice, but it is worth trying both ways just so that you are aware of what you may be missing if you do opt for single dosing.
Full stop.
While I'm in quote mode: A while back you posted
we need to lighten this up!
Hear hear!
After all, it is Christmas.
And frankly until you have done some valid comparisons of your own, either on your own or in company to do them blind, or I have managed to get together with some people to do some blind testing here in the UK, I honestly don't think there's much either of us can add to this other than:
Merry Christmas!
and
Enjoy the coffee!
Cheers
Mike
[Edit] I posted this just after your last post, Jon. When I wrote "not about you", I meant this thread. I meant that I was insisting not to lock horns with you, or Jim, or anyone else, but because this is a practise that is seen to be advocated on the forums and is one of the few instances in my experience of a big trade-off where quality is sacrificed - you gain a fresh grind, some convenience and save coffee by single dosing, but don't get the very best out of your grinder. I have simply wanted to ensure that people took making the comparison seriously. The science is not against that.
LMWDP No. 237
