depshrink wrote:Much to my surprise, I found that one of the cafes didnt grind their own coffee beans, rather, they have theirs ground by their supplier. I believe that they described their coffee as being a "number two" ground. They even gave me a tablespoon of it to take back home with me. The first thing I noticed that these grounds were considerably finer than I have been able to get from my Super Jolly. Also, the coffee grounds are a pure dark brown. My grounds are lighter brown with flecks of white.
That's because your coffee is fresh and theirs is stale. Even after roasting, all coffee has some residual (whitish) chaff; it's easy to see in the little line that separates the two bean halves. When you grind fresh coffee beans, the fragments of the chaff are mixed in with the grounds. However, when it is preground and packaged, the chaff has time to absorb the coffee's oils and discolor, resulting in a more uniform shade of brown. When it comes to ground coffee, perfect color uniformity is not necessarily a good thing.
One of the roaster's at Counter Culture and I were talking about commercial, large scale preground coffee. He pointed out that chaff is lighter and naturally rises to the surface of a heap of ground coffee. He visited a large coffee factory and saw that the troughs of ground coffee had a large auger down the middle to mix in the chaff fragments so the coffee looked uniform to the consumer.
depshrink wrote:I am beginning to suspect that these flecks of white are a result of having dull blades ( I have since ordered a new set of burrs). I find that as I turn the adjustment wheel to make the grinds finer, I come to a point where the coffee grounds do not discharge into the doser. The machine seems to "clog" up. I have to turn the wheel to a much coarser setting for the grounds to finally exit the burrs into the doser.
Have you cleaned the burrs (
instructions)? The grinder is used and it would not be surprising if the burrs are caked with oils. It can build up to the point that it becomes a hard resin; not pretty. After you confirm the burrs and chamber are clean, rezero the burrs and then back off approximately 1/8th turn to arrive in espresso grind setting range.
Tip to reduce waste: Learn to adjust the grinder based on the feel of the grounds. A teaspoon is enough to check the granularity and moisture content. Grind a sample and pinch it between your fingers. It should feel much coarser than flour, but less coarse than salt. The grounds should stick together slightly; if the beans are fresh and the grounds don't adhere together, it's too coarse. If the grounds hold a fingerprint impression, it's too fine.
depshrink wrote:Is the fact that I am getting white flecks especially in my coarser grinds, and that the machine clogs up when attempting a finer grind symptoms of dull blades? This clogging begins when I am near 2.5 on the dial.
Signs of dull burrs include finer and finer settings necessary to get a decent pour, uneven grind quality, clogging, etc. Below is a closeup of what flat burrs look like when brand new. You will easily feel the difference in sharpness between your new burrs and the old.
Courtesy of Al Ruscelli's Mazzer Mini Burrs
