by randytsuch on Sat Aug 29, 2009 10:46 am
Hi
If you are right, and they already changed the motor, then you DONT want to plug it into 220/240V, a motor designed for 110 will not like 220V, and you'll most likely blow it up.
But, you can do the reverse, running a motor designed for 220V at 110 won't hurt it, it will just run slower, and not have as much power.
If it was me, I would try grinding some beans at 110, and see how long it takes to grind them. Would be better if you could weigh the beans, so you could figure out how many grams per second it is working at.
Randy
