by morethancoffee on Tue Aug 25, 2009 3:37 pm
Hi
I just purchased a second hand Astoria Super Jolly manuale. An older Model I guess. I replaced the grinding plates with brand new ones. It is grinding good for an espresso, but I find something weired about it:
If I set to maximum fine grinding level (so that the discs/burrs start to touch & sound slightly), the Astoria is still not grinding fine enough to block the water when brewing with my Rancilio Silvia. I always thought, that at the maximum level of the Super Jolly, I have to be able to grind so fine, that no water will come through.
But this is not the case. Why not? Is this normal? Anybody experienced the same behaviour?
I have also a Silvia Rocky and with that one I can easily set the grinding so fine, that no water gets through the Silvia. Both have new grinding discs/burrs.
Any experience/ suggestions are welcome
Another question is, whether it is possible to figure out the production date of my Astoria.
The Label sais on the left side:
MM
MM
Mazzer
Super Jolly Manuale
N 9703382
220-230V / 50hz / 350W
On the back of the grinder is the red Astoria Signature in big letters on it.
Thanks in advance
