So for the last nine months I've been using a PL53 grinder with my PID Gaggia Classic with very nice results. My biggest complaints with the grinder was the noise. My routine would be to grind ~18g of beans at a time which would yield ~16.5g of grind (16g dose in the basket with a little left over that I tossed). Started out doing a lot of redistribution and WDT prior to tamping but over the last 2 months settled on just spinning the basket as fast as I could while the grinds fell in. The centrifugal force would break any clumps and then spread the grinds to the outside of the basket first and then up the middle resulting in a nice even mound. Then a quick tap down on the counter, tamp and pour. Great results in terms of taste and bottomless pour. Then when I was done with my drink I would take off the chute cover and sweep the chute clean, pulse, sweep again and then reassemble the chute for the next drink. Not too crazy.
Then as soon as I got everything consistent and reproducible I felt a need to upgrade. I was deciding between the M80, the M80E and a Baratza Vario. So far I'm happy I got the Quamar but the jury is still out as to whether or not I would've preferred the "E" model.
Here's a picture of my setup:
I decided on single dosing because I wasn't too happy with the stock hopper or the mazzer mini hopper I got. Additionally, the mazzer hopper's neck is a little too small for the Quamar. Here's a size comparison of the two hoppers in case anyone's interested:
The doser and single dosing with the larger Quamar took a few tries to get used to. As my first stepped grinder I found it interesting that using 16g of Redbird at a setting of 14 I choked my machine but at 15 I got a spritzing gusher. There are 5 steps between those two numbers in case anyone is interested. My current routine involves sacrificing ~5g of beans to clear old beans from the chute and then clearing the doser. Then I grind ~19g of beans, sweep the beans left in the grind chamber down, pulse grinder and then dose into my portafilter. With no WDT and a slight redistribution in the basket before tamping i get a great shot (16g dose:30-32g espresso). My standard ratio is 16g : ~28g so I can't do a direct comparison of taste to the PL53 yet. Then for cleanup I just pull on the doser arm until the doser stops dropping espresso. Here's a look down the doser after about a pound of espresso through with no cleaning:
I will probably start sweeping the doser every weekend or so but the stray grinds aren't bothering me too much right now. The one big issue for me right now is cleaning the chute. The overfill switch kind of prevents access to the chute so I might go ahead and try to remove it.
Overall I'm happy with the look and feel of the machine and the espresso, still not at my standard brew ratio yet to directly compare to the PL53 but the drinks have been better than the comparable highish ratios using the PL53. Also, the grinder is MUCH quieter than the PL53. The next things I plan on addressing are the doser switch and getting an ebay plugin timer for the grinder. Even if I spend ~$50 on a used gralab timer I'm still $100 less than the M80E. Still unsure if I'd prefer the M80E...
Thanks for bearing with the rambling post. A pound of espresso in 24hrs will do that to you
