by julies on Fri Feb 11, 2011 10:18 am
Well the good news is we got both burrs out and the new in. Quick FYI to anyone considering replacing the burrs on this model; the part doesn't come with any instructions and tech support from the retailer is $30 for the first 1/2 hr. At any rate, we were able to get everything apart except the top burr from the carrier. It is plain to see that there is no screw or anything locking the burr in place, but boy is it tight! There has to be some trick, but we just kept at it and gently secured the top carrier in a table top style-vice using the outer ring of the top carrier to support and the vice to gently hold the threaded part below the outer ring, then used the widest (also somewhat thicker), flat-blade screwdriver we had, rested that against the burr, and gently tapped the screwdriver down to slide the burr out of the carrier. Wah la! Be sure to be cautious when setting the top carrier in the vice because the carrier appears to be plastic. One other FYI for anyone attempting this replacement is that the lower burr bolt is reverse threaded and uses a 10mm socket. Best of luck to anyone taking on this work. It is possible to do without breaking any parts. Wish we had taken pictures of this to be more helpful. Sorry.
