Too coarse, next moment too fine !!! ?
Postby Coffeeguide on Sun Aug 21, 2011 3:10 pm
Having some difficulty in setting the correct grind setting.
When adjusting the grind setting, it turns from too coarse to too fine.
Going in reverse, up the scale again, it remains too fine, even on the numbers where it was too coarse in the beginning !?
Feeling the shaft with my finger when it turns, I feel a slight wobble.
So its not completely centered.
Any ideas what causes the grind setting variations ?
Hear from you shortly...
Ciao Bernard
Coffeeguide
Postby HB on Sun Aug 21, 2011 3:30 pm
Coffeeguide wrote:Any ideas what causes the grind variations ?
Which grinder? Are you purging the grind chamber? Weighing the dose? Maybe the variation you attribute to the grinder is actually variation in your technique.
Postby allon on Sun Aug 21, 2011 3:47 pm
Are you running the grinder while you do the adjusting? You can get erratic behavior like this if you don't. The channels in the burrs get all plugged up, throwing off the grind. Disassemble, brush out the burrs, then reassemble and try again, being sure to run the grinder while adjusting, then purge the mixed grinds and start from there.
LMWDP #331
allon
Postby Coffeeguide on Sun Aug 21, 2011 4:05 pm
Hello,
I will give it a try while the machine is in action.
Thought you had to do the adjustments with the power off.
This to avoid teeth-grinding from the burrs.
It's a learning-curve,
thanks for your response
Will let you know if it works. :)
Grinder Rancilio MD50
Coffeeguide
Postby allon on Sat Sep 03, 2011 10:01 pm
Did it?
LMWDP #331
allon
Return to Grinders
