by shadowfax on Tue Jun 09, 2009 1:20 am
Use both.
Timers help with repeatability; that is, some of them do--the ones that are that effective. The Vario is such a timer; it's remarkably consistent during a session, and pretty decent over a few days with a coffee, requiring only minor tweaks as the beans age and the temperature and humidity change. It is somewhat sensitive to grind changes, naturally (some timer-grinders are EXTREMELY sensitive to grind changes), so you will have to be mindful of that, or simply avoid changing your grind by making setting your base grind/dose and then making fine adjustments to your dose, using the timer to tweak shot times, instead. Of course, adjusting your shots in this manner means you need to be mindful of whether your dose gets too high or too low for the coffee you're using; you could end up with issues like over- or under-extraction, or just not enough headspace. In practice, you notice this excessive drift, either by looking at the mound of coffee when it's dosed or when you've tamped it and the piston goes down too far/not far enough. Then you make a grind adjustment to compensate and tweak the timer to get the right shot time. I've been using this on the Vario and the Nino, and I like it. In my experience, I usually decide to change my dose significantly (requiring a grind adjustment) or change coffees well before I drift out of the range of the grind I've chosen.
But, I also weigh my baskets almost all the time, just to make a mental note of the dose and how consistent it is. I have a larger scale that I can rest the entire portafilter on, and I tare it for quick weighing. I find that doing this has helped me get a better feel for the pitfalls of adjustment and a sense of scale so I can dial in a coffee faster. Eventually the scale goes away, when you either learn to dose visually/by hand as consistently, or you learn how to adjust your timer in a useful manner. But until then you need the scale, and of course it's great to have for re-calibrating yourself or just seeing where you're at. You'll want this if you're trying to replicate a roaster's recipe (18.5g at 199°F), or you want to tell someone what dose you like blend x at without talking out of your behind.
Again, why the vs.? They're perfect companions. And scales are (or can be) so cheap they're an afterthought.
Nicholas Lundgaard
