by Randy G. on Wed Dec 01, 2010 2:29 am
I have not owned all that many grinders, but I can compare two I have owned - the Rocky and a Mazzer Kony. Now these are two VERY different classes of grinders, but the Kony shares the same upper burr adjustment and mounting design with the other Mazzers I have owned. The Rocky was my first grinder, and back when I bought it, the Rocky was about all there was to choose from in the entry level league. It was highly regarded back then because without having to spend substantially more it was about all there was to choose from. It was also highly regarded by a number of the knowledgeable folks who frequented alt.coffee, which at the time was THE place to go for coffee info and assistance. I used it for about 6½ or 7 years. So like so many others, I was quite pleased with the Rocky. It is no wonder that with all the support it got, the Rocky drew a good percentage of folks setting out to start making espresso at home, and those who were moving up from whirley blade and cuisinart grinders.
But like shock absorbers, until you switch you don't realize how bad the old ones were. Comparing the simplicity and rock-solid performance of a Mazzer to a Rocky exposes the Rocky for what it is. A nice grinder, but one which could have been a lot better. And while Rancilio changed the original plastic case to stainless, they did nothing to improve the precision of the way the hopper/upper burr system works and the adjustment design. When you consider that one click on Rocky is about a 0.001" distance between the burrs (if I remember my math), then the amount of rocking motion experienced in the upper carrier is, to me, unacceptable. We can talk about burr quality as well, but that is for another thread.
So that is why, for the last year or two I have been responding that, for the money, a used Mazzer is a better investment than a new Rocky. If Rancilio would address the issue by spring loading the upper carrier and making the Rocky stepless it would be another matter. Then, for the money, it would be a much better investment than it is now. But I think they would have to tighten up the tolerances and maybe use a better design which would eliminate the wobble and play in the upper burr carrier. And with one click on Rocky being about three to four seconds of extraction, it makes me appreciate my stepless grinder all the more.
So the wobble of the upper carrier is normal, and the whirr.. whirr.. whirr.. cyclical sound is normal for a Rocky. The teflon tape mod takes care of that, and also makes the Rocky a better grinder for espresso.
I suppose I am a little bitter from the disappointment to have found out so late that for all those years that I could have been making better espresso and had better control over the grind if I would have gotten a better grinder right off.
