JohnB. wrote:Get a quote from Owen @ Phaelon Coffee for the Mazzer parts before looking aftermarket as he has the best prices I've found. You can bypass the start function & make the switch work as a standard off/on switch by adding jumpers where the two doser switch harness leads attached. Possibly someone messed with these connections & thats why the start function isn't working??
OK, thanks for the heads up about Phaelon, Chris seemed to have the best prices for burrs, but I will check phaelon too.
I am not sure what you are saying about the switch. My switch (both units) has three positions, OFF-ON-START. Off is obvious. On turns power on, but only up to a relay. Start is a momentary setting, which shorts two wires together, and activated a relay, which turns on the grinder. In the original configuration, there were two ways to start the grinder, with the off/on/start switch, and there was another switch, in parallel, connected to the doser. After 10 or so doses, this switch would short, and turn on the grinder.
When I got it, I could not turn it on with the START switch, and I accidentaly found out that if I pulled the doser enough times, it started. I only figured out why later, after I pulled things apart.
Now, I have removed the doser start switch, and added one small switch, which I can use to short the wires, and turn on the grinder.
I didn't buzz out the wires going to the START switch, to see if they are correct, but I did not think anyone would have messed with them, although there could be a broken wire, so I will check that out.
Randy
