innermusic wrote:...to run thru the grinder, instead of Grindz (too expensive). Can use oats (flat, or rolled)? Or something else?
The Vario, with its exceptionally low grind retention (very small space between the lower burrs and the grinding chamber walls, short exit chute, overall very good design) is very easy to clean and except for very small accumulations in some cracks (mostly: screw heads, junction of the lower burr and its carrier), almost nothing is retained. Cleaning is probably not needed as much as it is with other grinders (compared to my own experience with the Rancilio Rocky, which needed extensive cleaning, with a shop vac and an hour or so of free time to disassemble, clean and reassemble).
The only issue when cleaning the Vario is grind adjustment. Inevitably, each time the upper burr is removed and put back, the grind shifts in a substantial manner, often justifying an adjustment right after, with the included Allen key, to keep the micro lever in the espresso range (to avoid having to resort to the Allen key later to grind finer than the finest setting or having to play with the macro lever when the micro lever set to coarse is not enough).
Therefore, for those two reasons, I personally don't clean it as much as I thought I would need to and I always find I could still have waited more before doing it.
