The Hypothesis
In all the heat about whether single dose grinding is worse than hopper grinding, the really interesting question has been lost: how the heck can you get two different grinds from the same burrs at the same burrs spacing just by changing the ways the beans feed? As a penance for contributing to all the heat, I thought hard about this. Here's what I have:
The diagram shows the two alternatives by looking at the upper and lower burrs edge on, with the beans exiting from the gap between them.
Testing the Hypothesis
There is no way the contrast between single layer/single dose, multiple layers in hopper grinding is 100%. But the hypothesis implies there will be more multi-layer ground particles in the hopper grind. This means that the distribution of coarse grinds will be more dispersed for the hopper grind than in the single dose grind.
In the TGP, we found that the conicals were more forgiving than the flat burr, since the dispersion of coarse grinds was wider. This means that if the hypothesis is correct, hopper grinding will be more forgiving than single dose grinding..
This should be a lot easier to test than taste. Once you have both grinders dialed in, change the setting by a fixed amount on each. The flow and shot timing on the hopper one should be less affected than on the single dose one.
It may also mean that with meticulous grinder prep, there will be little difference between the methods, while with more casual prep, the hopper grinds will produce more successful shots.
