by another_jim on Mon Dec 28, 2009 1:42 am
Calling it a contest is a conceit, but my intent is serious. Should the grind setting alone be changed and the dose be kept the same? Or vice versa? Or may split the difference with a small changes to both dose and grind? There is no "natural" answer. If the taster picks a shot profile they enjoy using one alternative, say single dosed; the shot puller should look at dose change only, grind setting change only, or something in between to see which seems closest in taste. This seems less controversial than picking how to go between grinder configurations.
However, it may be best if you stay with the protocol of predetermined doses and settings. I've had some emails on this, and may be able to put together a replication test in the contest format. We would only have one of each grinder, so we'd have to grind single dose, then hopper, then single dose again and combine the two single dose grinds, so that the grind aging factor is physically controlled. I don't know if such a staling control will be perfect, but it's probably better than nothing. We'll also reverse the grinding order in each round as a design control.
