another_jim wrote:If some of the beans are cheek to jowl, they can't spread out, and will get crushed into stacked particles instead. These will pass out of the fixed gap in the burrs stacked, decreasing the coarse particles' average size and increasing their variance. That is what I am hypothesizing. It explains the differences in what people found, and it can be very easily be tested.
I think you have missed the point of what I am saying. You have stated as axiomatic to your hypothesis that
another jim wrote:You need to grind finer for single dose grinding. Therefore there's larger particles, a more uniform grind, and/or fewer fines
and I propose to reject this axiom as conjecture. Thus, any results from the experiment you have proposed will not in fact be conclusive, unfortunately.
Further I have concerns about the idea that cellulose can be compressed in this fashion, as it tends to have limited capacity for plastic deformation leading rapidly to failure/fracture in a dried state, which is why we soak wood before trying to bend it, etc.
another_jim wrote:Again, does anyone have a different prediction for the compared particle distributions and the mechanism causing the difference?
What I am proposing as an alternative prediction is this:
The primary issue differentiating hopper versus single dosed grinds is not within the burrs where the particles are relatively constrained but within the coarse conical grinding teeth, where the beans are unconstrained to the point of flying about in erratic "popcorning" motion in single dose grinds.
My analogy here is chopping a tomato. If you can hold it with your other hand (hopper), you can make a uniform dice. If you don't (single dose), the chopped pieces are irregular.
BUT it doesn't stop there.
Then the bean fragments enter the burrs. Imagine each fragment as a rectangular loaf of crusty bread. It has six crusty sides. Cut it in half and each new loaf has five crusty sides and one smooth white side. And so on. Because you can't cut anything on its edge, the final ground particles retain the effects of the initial fragmentation process as surface irregularities.
BECAUSE surface irregularities are not necessarily dependent on particle size and fines production, I am not clear on what predictions we can make about this. However, the more irregular surfaces produced by single dose grinds will effect particle stacking behavior
so we predict that in general a tighter grind will be required for single dose grinds, but that the degree of the effect will be somewhat unpredictable since surface irregularities by definition will be semi-random in nature.
FURTHER since, just as slicing that loaf of bread repeatedly yields more and more exposed flat white inner surfaces in relative proportion to the outer crust, a finer grind should likewise reduce the effect of the surface irregularities.
Thus we predict that for increasing finer grinds, the difference between hopper and single dose grinds will become minimized.
