shadowfax wrote:[emphasis mine]
I agree with you for the most part, as do I think most of us. I also agree that a mechanism for quantifying reproducibility in addition to just the comparative taste is important. However, I've totally lost you at the bolded comment. It seems like you waste a minimum coffee when you're running pre-weighted, single dosing vs. keeping a hopper full, where you (maybe) have to purge after making grind adjustments, after leaving the grinder to sit idle, etc. Did you switch the two around, or am I missing something key here?
Here are the sources of waste using single dosing using what I would define as good technique:
(1) If you assume that there is going to be coffee left over in the grind path from whatever was ground before, then you need to purge that. Simply running the grinder until no more grinds come out then using a chopstick or other implement to clear the chute(s) will still leave at least "some" of the former coffee in the grinder and the only way to expunge them will be to use some of the next coffee to push them through. This is certainly how I would do single dosing if I followed this practice, if I wanted to be sure that what I was tasting on my next shot was close to 100% of whatever coffee I intended to drink. So, if it were me, I'd purge the grind path with 2-5 grams of the next coffee and discard it before I loaded the preweighed amount into the hopper. Not purging what is left in the grinder means you will be drinking a melange of what was in there before and what you want to drink, now. Can people taste the difference? I don't know, but it would be worth the several grams of the newer coffee, to me, to eliminate this risk. Alternatively, you could change coffees using the first grind of the new coffee in a milk drink, if you make a lot of milk drinks daily.
Theoretically you could do this before each shot even if you didn't change coffees often, however testing by Abe and others on coffee ground up to 12 hours before and used in espresso doesn't support the notion that there is marked deterioration during this sort of time period, so in the scenario of not changing the coffees in the grinder often you could just purge it once a day, in the morning, and be fairly confident that no further purging was necessary.
(2) When you change coffees, no matter how you dose, the grind usually changes. Perhaps some people are so good at adjusting their grind settings on the fly that they can adjust for this, but I would suggest that most people are not good enough with this technique to avoid extra waste. The extra waste would come from either producing a higher proportion of sink shots or from drinking substandard shots that would require further grind adjustments in order to nail the grind adjustment necessitated by changing coffees frequently.
I think these things could be tested along the lines of what I suggested in my initial post, although as I also noted I doubt that whatever would be observed would change anyone's behavior so doing the study would be optional.
As to my own personal opinion, I'd suggest that for those who want to change coffees very often that it might make more sense to buy TWO of a very good but cheaper grinder (say a Max) instead of one more expensive one (a Robur or a Compak, for example) and by having two grinders one could always have at least two coffees available for immediate use, or even three coffees available on any given day by cycling the grinders among coffees every other day rather than cycling one grinder 3 times per day.
Just my opinion, and I doubt that this or any other similar thread will change the behavior of even 3% of those who read it.
ken
Moderator note: topic split from Single Dose Versus Hopper Grinding: Hypothesis about the exact difference. See the original thread for context.
