Simple OE Pharos grounds catching mod
I just got my Pharos II from OE tonight and have been seasoning / testing the grind sizes at various turns from zero.
In the process, I happened upon a bowl in the cabinet that fits PERFECTLY in the bottom rubber ring on the grinder as a grind catching vessel. You can bang away to ensure no grounds loss and it WILL NOT COME LOOSE!
Using this method with a good couple of taps, I was able to get within .1 grams of the coffee I put in EVERY TIME. Most often, my reading was the same as the input (pre-grind) weight.
E.g.:
After grinding, you simply remove the plug, attach the bowl, tap the grinder, and then remove the bowl and dump grinds in your pf.
I'm sure any bowl with a 3.5" mouth would fit; however, the particular bowl I am using has a nice arc to the bowl that makes it stay in the rubber ring better. Also, the foot at the bottom of the bowl makes removal of the grind vessel a breeze.
The bowl I am using can be found at the link below (and on Amazon):
http://www.homeessentials.com/modules/i ... p?id=63142
Oh, and a few Pharos Glamor Shots:
E.g.:
- CoffeeBar
Congratulations on your new grinder and hope you enjoy your coffee everyday
