Ross Droplet Technique-Eliminating Grinder Static - Page 10
- JohnB.
Here you go:FotonDrv wrote:John:Could you Post a photo of the mister bottle you are using? Mine is a bit cumbersome and I am looking for alternative.
Nothing fancy but it does put out a very fine mist that's hard to even notice on the beans but seems to do the job. Slightly taller then a tamper & pretty slim. If you look in the area where you find the travel size toothpaste, ect. there's usually a selection of various sized pump bottles. I'm going to pick up a second one to keep next to the Bunn as the RDT has completely cured the static cling all around the exit chute.
LMWDP 267
- JohnB.
This would certainly work but you'd have to thoroughly flush the wand each time to avoid soaking the beans.allon wrote:Hm, may have to try a small burst of steam from the steaming wand over the beans prior to grinding...
LMWDP 267
- FotonDrv
Thanks John
UPDATE: John! That is a beautiful tamper handle!!! Did you do it yourself?
- allon
Of course. Worked a treat!JohnB. wrote:This would certainly work but you'd have to thoroughly flush the wand each time to avoid soaking the beans.
I did a very gentle pass under the steaming wand. If I'd opened it full I'd have blown the beans all over the place - my machine is a steaming beast!
LMWDP #331
- JohnB.
No that comes from Pullman Coffee Tampers in Aus. http://www.coffeetamper.com.au/FotonDrv wrote:UPDATE: John! That is a beautiful tamper handle!!! Did you do it yourself?
My woodworking skills are limited to being able to use a table & chop saw and a router to recreate old woodwork in our 250 year old Colonial house. The nice wooden pieces on my espresso machines all come from Dave.
LMWDP 267
- JohnB.
I did try that with the Speedster & as I recall a few beans did go flying. I think the Cremina or an MCaL would be the ideal choices for this method.allon wrote:Of course. Worked a treat!
LMWDP 267
"The question I ask is, how much is enough? I think it takes less than what many of us use."
i find that, as a ball park figure, adding 0.15g of water to 15g of beans, works well for my Pharos.
- dcupstateNY
John, I have the same exact bottle. I tried it tonight for the first time ... worked like a champ with my Pharos! It's only in the teens here and the heat is on big time, consequently, it's dry as a bone! This process totally eliminated the static/ground retention that I usually experience. The question I have is how many "spritzs" do you usually apply to the beans? I did two 14g doubles in my LaPavoni. I spritzed each one 3 times before grinding ... too much?JohnB. wrote:Here you go:
<image>
Ciao,
Dave
LMWDP: #346
Dave
LMWDP: #346
- FotonDrv
That Speedster would be like my GS/3 and result in more of a pressure washing episodeJohnB. wrote:I did try that with the Speedster & as I recall a few beans did go flying. I think the Cremina or an MCaL would be the ideal choices for this method.
Thanks for the info on the tamper.
- TomC
dcupstateNY wrote:John, I have the same exact bottle. I tried it tonight for the first time ... worked like a champ with my Pharos! It's only in the teens here and the heat is on big time, consequently, it's dry as a bone! This process totally eliminated the static/ground retention that I usually experience. The question I have is how many "spritzs" do you usually apply to the beans? I did two 14g doubles in my LaPavoni. I spritzed each one 3 times before grinding ... too much?
Too much. Or not. It depends on what your retention/static looks like. Pretty much every type of epsresso roast I've put thru my grinder has all the problems cured with one quick spray. Do a test grind weighing before and after if you need to, but I think you're overthinking it.
