Ross Droplet Technique-Eliminating Grinder Static - Page 2
- Supporter ★
Great tip! I'll try it with the Indian Monsooned Malabar which is extremely static. Always had big problems with the static charge of these beans and grounds being all over the place.
- TomC
Take pics and report back if you can. This will be an epic thread for home coffee enthusiasts. Who hasn't dealt with grind retention in one way or another on a grinder, manual or electric?
This is Maaagic ,
Thanks a lot for the trick, almost no sticky fines on my yoghurt funnel!
- Bob_McBob
I would imagine an eye dropper or pipette of some sort would be a worthwhile investment if you want to keep doing this.
Chris
Also thought about an eye dropper. That would be perfect with single-dosing. Going to get one this afternoon and see how it goes.
And a pipette will fit perfectly next to my dissecting needle!Bob_McBob wrote:I would imagine an eye dropper or pipette of some sort would be a worthwhile investment if you want to keep doing this.
Ryan
- Spitz.me
So some quantifiable results with the k10 - as if pictures weren't enough.
20.7g IN
15.9 OUT into the DOSER 76.8%
4.8g RETAINED in the chute and upper chamber. 23.2%
100% OUT
Give or take .1g error and/or .1g from the earlier shot.
I will check, for myself anyway, what the difference is without the droplets of water. But, I seem to be recalling a number closer to 8g retained in the chute and upper chamber.
This makes the bumping and grindings a little easier just because there's less 'aggressive' sweeping that needs to be done as they move out of the chute more easily.
I also checked after I finished my espresso how much I would have to clean from the K10 and, although the retention is .1g or so usually (very small), it was similarly very little retained that I had to clean. However, the grinds move more easily.
20.7g IN
100% OUT
LMWDP #670
- Boldjava
Water on the beans? It's Winter here and the heat is on. Humidifiers balance the moisture in the air for us since the furnace takes it out of the air. With the humidifiers running, I see only very slight static and don't have need to put water on the beans.
LMWDP #339
LMWDP #339
