Removing taste of flavored coffees from used grinder
I got a la cimbali grinder and the previous owner used flavored beans, how do i get that taste out?
Thanks for any help, would grindz or rice or something else work?
Matt
Matt
Its my understanding that grindz removes the leftover traces of coffee and its oils. Manufacturer states it is rice based. Ive never used the stuff but heard good things. I would try it - before going to the next level. Which would be the tear down and manual deep cleaning.
- LaDan
If you got it used, I'd take the grinder parts out so that I can manually clean everything in there and start from a "clean slate". You don't know what kind of junk you've got there. Take a hard bristle toothbrush and clean that out. Vacuum. Paper towel with alcohol for the oil and flavor residue.
After that, run some of your own good coffee to coat the burrs with some of your coffee oil since the alcohol dries that out. The oil from your good beans gives it some protection coat.
I wouldn't even bother with Grindz in your case. You don't even know what you have there inside.
- aecletec
Excellent method from LaDan there, followed it for my ex-cafe grinder and worked a treat - it didn't smell... tasty when I got it, the dust and oils were stuck everywhere! It turned out super clean with just a bit of scrubbing, no residual funky flavour etc.
- cannonfodder
Joe-Glo worked for me. On my Bunn, which had moldy beans in the burrs. I did a full tear down and washed everything in Joe-Glo using hot as you can stand water. That helps lift the oils off the metal and plastic. Then a good drying so nothing rusts.
- HB
- Admin
It's an old thread, but that's what Dave documented in Reviving an Abused Cimbali Max.LaDan wrote:If you got it used, I'd take the grinder parts out so that I can manually clean everything in there and start from a "clean slate".
