Problem disassembling Mazzer doser
- BartG
Hello,
I'm working on a Mazzer super jolly. Here are before and after pictures:
It was an automatic version and I removed those functions. A new layer of paint and a thorough clean-up should cover the aesthetic aspects.
The machine is grinding fine (also put in new burrs), but now that I'm actually using it I'm looking into some modifications (naturally ).
This is where I have a problem. To clean it I fully disassembled the doser and put it back together. But now I would like to install a sweeping mod. The problem is that I no longer can unscrew the big nut that also controls the height position of the sweeper vanes. Maybe I put it back too tight? (It is now much lower than before the restoration - see pics). I do need to turn it counterclockwise to unscrew right?
My question now is: would it be relatively safe to use a wrench on it, or might I damage the doser mechanism this way?
- erics
- Supporter ★
This should help: http://www.fotchbook.com/faq/mazzer/index.html
- BartG (original poster)
Thanks, in taking apart his doser he writes: "On the inside of the doser, unscrew the star shaped nut. This will take many turns and you have to hold the "sweeper" from rotating"This should help: http://www.fotchbook.com/faq/mazzer/index.html
On my doser the sweeper only turns when I turn the starshaped nut in a clockwise direction.
Could someone please verify if clockwise is the right direction to unscrew it? Just so that I don't wreck mine because it's pretty stuck now.
- erics
- Supporter ★
I HAVE NOT disassembled a Mazzer doser. HOWEVER, given the thoroughness of the restoration manual I linked to, I would assume with a lot of confidence that the threading on the bolt you are trying to loosen is a normal right-hand thread, i.e., turn counter-clockwise to loosen.
The best type of tool to use is what is called a tee-handle wrench.
