by galumay on Tue Jan 17, 2012 8:00 am
I would compare the Pharos grind quality to the big commercial conicals, its in a class of its own compared to something like the Rocky or Vario.
I personally havent found the ergonomics a problem at all, i hold it against my hip and have no issue with that aspect, its quick and quiet. (obviously!)
The grounds retention is no longer an issue with the funnel setup, i basically get out what I put in.
As I am a Lever user I love the fact that my coffee making routine involves no noisy motor driven machinery, but even if I used a HX or similar I think I would stick with the Pharos, for under $300 its crazy value, to get similar grind quality you would have to spend nearly 10 times as much.
LMWDP #322 i started with nothing.........i still have most of it.
