Owner experience with LIDO cupping coffee grinder by Orphan Espresso - Page 23
- Supporter ★
Just curious: while at work, do you not find it a little messy? My LIDO hasn't left the house yet, which is why I ask. I'm in the habit of brushing off its underside over the kitchen sink. In an office setting, maybe I'd use a trash can instead.Sam21 wrote:The LIDO is a really convenient grinder for the office and allows me to enjoy great coffee at work whenever I want...
Unrelated: in case anyone was unsure, the glass catch jar is dishwasher-safe (in my experience).
"It's not anecdotal evidence, it's artisanal data." -Matt Yglesias
After a week and a half of use in my office, I have found it very pleasant to use. I give it a quick shake after grinding to loosen any immediate dust/chaff. I leave the remaining clinging material on the grinder when i remove the jar. Then I give it a quick blow/shake/brush over the garbage and it's good to go. I've made some wonderful CCDs in the office with it and am really happy with it in this arena.
- allon
Light roasts will come out very cleanly with minimal residue.
Dark roasts will leave static-y bits all over the jar and adjustment mechanism.
This might explain differing experience.
LMWDP #331
I am grinding roasts in the City+ to Full City range. I hardly ever have a bean in there that has gone into second crack.
- Supporter ★
^^^ +1. I've found it's not so much roast as it is grind that makes a difference re: "mess." Coarser grinds allow more chaff through. A finer grind, e.g. 1 turn CCW from zero, is often neater.
I just did a thorough cleaning of my LIDO and am noticing that my zero is now a quarter turn finer.
Every now and then, I remove the inner burr by taking off the adjustment bar for a thorough cleaning. My regular routine is to just brush and blow fines away from the burrs and that works quite well. Over the past 2-3 weeks, I have been using my LIDO a lot more than usual as it now resides in my office. I have noticed that the rub at my zero was getting quieter and quieter. After this cleaning, the rub was simply not there, so I set the LIDO at -25 and got a nice rubbing sound with only a tiny bit of friction (Not enough to lock up the burr, just a decent rub). It would seem as though my zero has been settling finer bit by bit, but this cleaning and adjustment bar removal settled the zero into a quarter turn finer.
Has anyone experienced a similar settling? I likely will not move the gold washer since I know exactly where the zero is. For all you regular LIDO users (I am just becoming an everyday user), what have your experiences been with this?
- Supporter ★
Yup, my zero is at 1/4 turn CW from where it began. Seems to have stabilized there, though I know a few others posting in this thread have experienced a little more settling. Doug @ OE commented on the issue back on p. 18. I haven't bothered to move the brass washer.
I doubt I will move it either. My zero is kind of in between the original zero and a -1/4, but I'm sure it will settle a little further so that -1/4 becomes the true zero. I first noticed the change when I began needing a finer grind to get good extractions in my clever. It was at that point that I noticed the rub at 0 becoming faint and then after today's burr removal cleaning, the rub was completely gone at the original zero.
Ah well, I guess my LIDO is finally being broken in!
Mine has moved a whole 1/2 turn after some use and a finicky alignment. The Pharos is easier to align down to 1/8 compared to the lido.
After another cleaning, my zero has returned to the brass washer. It may have had to do with the tightness of the nuts that bolt down the adjustment bar. I repeated the removal and reassembly of just the adjustment bar to see if there was any variation to the zero and it remained constant. I made sure the nuts were nice and tight (without over tightening then).
It's very interesting. In the end, I think it matters less where the zero is down to the 1/8-1/4 turn, because I still know how far out from the brass washer I need for a certain grind. I'm still using 1 1/2 to 1 5/8 for my clever. That really hasn't changed a whole lot. Gives me a nice minute on the drawdown.
