by Beezer on Tue Jul 21, 2009 2:54 pm
It takes time to adapt your technique to a new setup. Hard to say what's going on here based on your description, but you may need to grind finer and possibly dose differently. How much are you dosing right now? What kind of coffee are you using, and it is fresh?
If you don't have one, it's useful to get a gram scale for dialing in your dosage. I find that my Anita works best with a dose of around 18 grams for most coffees that I use. I can usually get an 18-gram dose by overdosing the basket and sweeping level using a pseudo Stockfleth's move to fill in any gaps in the dose. You also need to be careful to get your tamp level, as any unevenness in the tamp can lead to channeling. Weiss Distribution Technique (WDT) can also help if you're having trouble with clumping. Other than that, you just need to practice and figure out what works best for your machine, grinder, coffee and your own personal tastes. You should be able to get awesome results very soon if you keep practicing.
Lock and load!
