New Mahlkonig "PEAK" grinder - Page 9
- weebit_nutty
Very nice!
Although TBH, such a demo is worthless without proof those grounds can produce a proper extraction. They seem rather coarse to me.
Anyone going to SCAA that can report back?
Any new info on this grinder?
- Maxwell Mooney
weebit_nutty wrote:Very nice!
Well, they didn't post a video with those grounds specifically, but they did post this photo showing a 21.26% extraction yield from a 20g dose (rather high) with 43.2g beverage yield, and 27s extraction time. It was with an Olympia Kenya filter roast coffee, which by all rights is probably one of the hardest coffees to extract that you can find. Olympia is definitely a light roaster, and Kenyan coffees are quite dense. Pretty exciting stuff, as simply attaining that level of extraction has been very very difficult with espresso.
"Coffee is evidence of Divine Grace, flavored coffee evidence of the Fall" -Kevin Hall
LMWDP #406
LMWDP #406
Anyone with an idea of what the grind rate is on the finest setting?
It could be as complex or as simple as you want. It's the choice of the barista.
- cannonfodder
I may have to try honing my burrs some day. I do a lot of sharpening, straight razors, knives etc... so I have a large selection of stones going up to 12,000 grit. I have some very small fine stones uses for touching up the blades on my wood working equipment, jointers, plainers... anything using a small set of cutting blades. I bet I could use a small triangle stone or thin flat stone to refresh the edge on my burrs. It would be a long slow hand honing process but I dont know why it would not work provided the burrs were not chipped.JohnB. wrote:Both Bunn & Ditting will resharpen their cast burrs up to 3(?) times. I've never seem any company offer to sharpen one of their machined burrs.
- AssafL
It may be easier to hold the stone in a vise (use something soft like a rubber mat so it wont chip - or use a Panavise with plastic jaws) and use perpendicular motion on the burr. It may also be possible (and probably easier) to use a dremel disk as a sharpener. I may try that sometime.
You might also consider just "lapping" the burrs on a flat surface (stone) to just polish the outer flat surface that does the fine grinding ?
