cafeIKE wrote:It's only terrible if it matters. Have blind tests proven that filed burrs perform better?
While I don't have blind taste tests to confirm, my experience and the corroboration of others confirms that there is a "break in" period for new burrs; the symptom is a drifting grind setting during the first couple days of use. Whether it requires 1 pound, 2 pounds, or 10 pounds is another matter. For test purposes, I grind at least 5 pounds, but it's a guess.
JonR10 wrote:...And if we want to justify the $2 cost, what if it takes just a pound or two for the break-in of properly finished burrs as opposed to your $75 for two kilos of coffee?
Not to excuse the lack of attention to deburring, but let's keep things in perspective. In a busy cafe, a new set of burrs probably last a couple months, maybe longer. In a home barista's kitchen, the same burrs would last 5-10 years. Sacrificing a few pounds of stale coffee and the 10-15 minutes it takes to break in a new set doesn't strike me as a terrible burden.
Back to the original question, regrettably the burrs depicted in the first post are typical of new burrs. With enough badgering, Rostik may be able to convince the seller to accept them as defective, if only to settle the matter. I would instead scrounge up some stale coffee, grind it, and move onto shot pulling.
