New Cimbali Junior / MAX Hybrid Espresso Grinder - Page 2
Postby ideor on Sun Nov 25, 2007 2:47 pm
hello chris :-)
and when do the ottone ones arrive? ;-)
ideor
ideor
Postby zin1953 on Sat Dec 01, 2007 3:43 pm
Ken Fox wrote:I got sick of looking at that ugly Compak conical in my kitchen and put it in the closet, to be replaced with one of the new Max's that Chris is now selling.
Ken Fox wrote:I know in my own use, that it was rare when I didn't have to adjust my Junior grinders on a daily basis, that my Compak got adjusted once a week or less, and that the Maxs need the grind tweaked a little a couple times a week. The tweaks needed by the Junior were large enough that I threw out shots with some frequency due to required grind changes. This happens seldom with the Max and happened almost never with the Compak. I am referring here to a situation in which the same coffee is being used in a grinder over a period of a week, where the coffee is changing due to aging of the coffee and environmental factors.
Ken, I'm curious (and confused) . . .
It's seems as though you're saying the Compak is better than the Cimbali Max Hybrid, but it's the Compak that's in the closet? And it's just because the Compak is ugly? How ugly can it be, if it's better, to end up in the closet?
Or is the grind quality differential not that significant (or price differential not worth it)?
Cheers,
Jason
zin1953
Postby Ken Fox on Sat Dec 01, 2007 5:42 pm
zin1953 wrote:Ken, I'm curious (and confused) . . .
Cheers,
Jason
The Compak is "better" only in the sense that it requires fewer grind changes; the quality of the grinds themselves is indistinguishable, at least to my palate.
I have been back home (from France and California afterwards) for two weeks. I have been using the 2 old original design Max's and the new modified one during this time period. After I got the grinders properly adjusted for the coffees they were using (which are not the same ones they were grinding before I went off on my trip 2 months ago), I have had, at most, 2 sink shots in two weeks totaled from the 3 grinders, grinding 3 different coffees. During this two week period we have had weather that varied all over the map, from rain with 100% relative humidity, to our more normal cold dry air at around 15% RH or less. Small grinder setting adjustments have obviously been necessary during this two week period.
At this miniscule level of sink shots, due to grinder setting, it is very difficult to say that the Compak would have been enough better (in terms of grind adjustment) that it would be measurable.
The Compak is ugly. Granted, that is a personal value judgement, but I did not like looking at it in my kitchen or at the back of it from across the room. In addition, I found that adjusting it was unpleasant as it has a friction fit turning knob (like the Mazzers but less well executed) rather than the easily adjustable worm gear with clicks that the Cimbali Maxs have. The Compak has a large discharge chute that goes into the doser, which is hard to clean and retains grinds (as do the burrs). If you pulse the Compak repeatedly after the bean hopper is completely empty, you will get residual grinds coming out even on the 6th or 7th pulse. This tells me that the grinder burrs are retaining grinds and if you make espresso with the frequency of a home user, you are getting stale grinds as a significant part of every shot.
With the Max, when you pulse it, you get a little one time after the hopper is empty, and a microscopic amount the 2nd pulse. This tells me that the Max is not retaining old grinds in its burrs to the extent that the Compak conical does. I am reasonably certain that by cleaning the chute after grinding for each shot (and I use those grinds in the shot, whose coffee I weigh), if I then pulse 2g or so out of the Max before the next shot, and clean the chute, that almost all of the grinds for the next shot are fresh and not retained from the last one. This makes sense if you consider the design of the Max; the conical burrs are used for minor breakup and slight crushing of the beans; it is the planar burrs that do the actual shaving (grinding), and those burrs as designed just can't hold that much ground coffee in them when the burrs are set to grind finely, as for espresso.
None of this should be at all surprising. The Compak is a high volume full on commercial grinder intended for a busy cafe. In its intended setting, issues such as I have raised above are of no consequence. The Max is also a commercial grinder, but I don't think anyone would use it as a main grinder in a busy cafe, since its throughput is too small; it is designed more to be used in a place like a restaurant or lower volume commercial setting. It is smaller, better built, and more pleasant to use. The Compak will sell for somewhere between $1100 and $1500, and is intended as a low cost option for a cafe that might otherwise buy a Robur. Chris is selling the redesigned Max for $800 including shipping, which is a significant reduction from list price.
How do I know this about Chris's pricing? When I got my two grinders, the importer did me a special favor and sold them to me at half price, presumably hoping that my testing of the grinders and possible positive comments might result in this being a product that they could successfully import to the USA. The price that I paid for the original Max's, including shipping, was about $50 less than Chris is selling this revised model for, and I don't think that any significant profit was made on the pair I bought originally, which was done for me as a favor.
ken
What, me worry?
Alfred E. Neuman, 1955
Ken Fox
Postby zin1953 on Sat Dec 01, 2007 8:17 pm
Thanks, Ken -- appreciate the feedback! (Also your comments about updosing and an 18% Zin -- after 35 years in the wine trade, that makes a lot of sense!)
Cheers,
Jason
zin1953
Postby Lockman on Fri Jan 16, 2009 4:32 am
What a cool grinder! Slot head screws! Gaak! Maybe some nice FH torx would work to replace them?
Thanks for the write up Chris and Ken. I am in the process of liberating myself from some cash to get the best grinder for the $$.
Jeff
LMWDP #226.
"It takes many victims to make a culinary masterpiece"
Lockman
Postby chris on Sat Jan 24, 2009 8:03 pm
We are currently running an unadvertised special on the Max Hybrid grinder. We are offering 15% off, $760.00 that's a saving of $135.00. You need to call Monday thru Friday between 8:00 AM to 5:00 PM EST and ask for either Mary or Chris at 518-452-5995.
Chris Nachtrieb
Pres. Chris' Coffee Service, Inc.
chris
Postby RAS on Mon Jan 26, 2009 4:56 pm
$760 for the Max-Hybrid?! That is a screaming-good deal for a great grinder. I'm thrilled with the CMH that I've had for about a year now. Anyone thinking about diving into the realm of a Titan grinder ought to take Chris up on this great deal.
Bob
RAS
Postby RAS on Mon Jan 26, 2009 5:29 pm
Originally it was, but when the dollar was in its nose-dive, Chris raised the price to $895 - most likely when he placed another order. Yes, the dollar has gotten stronger, and prices should be dropping as a result, but as has been discussed at length around here, it will be a long time before (if!) that happens. To have a price like this... actually 5% less than the original price, pretty darn good.
Bob
RAS
Postby zin1953 on Tue Jan 27, 2009 11:49 am
Great deal on an excellent grinder!
zin1953
Postby tribe3 on Thu Jan 29, 2009 9:47 pm
Just earlier I posted that I was happy with my rocky and don't plan to change it... and now this!!
tribe3
Previous
Return to Grinders
