New Baratza Vario doesn't grind
Postby nau on Mon Jan 18, 2010 1:13 pm
Hi
Few days ago i got mailbox with new Mahlkonig Vario (European version of Baratza Vario) then i took a best coffee i could find here, put it in it, push "start" and what a sad - it doesn't grind. Motor is working fine, i could hear how grinds are moving but i can't see the coffee. I'm think there are too much space between grinds. I can't send it to RMA because it will cost another Vario.
could you give me some advices what should i do? disassemble it? change something?
here is pic
nau
Postby kyle anderson on Mon Jan 18, 2010 1:59 pm
Hi Nau,
If the motor is running (and the burr is turning) and it is not grinding any beans, there is a possibility that the polarity of the motor is reversed. A quick check is to press the start button with no beans in the grinder and look carefully as the burr spins to a stop (by pressing the start button again) to see if the burr is turning COUNTERclockwise. I also notice this is a Mahlkoenig branded Vario, not a Baratza. Where are you located? and is there a dealer near you? Certainly the Vario is covered by a warranty. Please let me know what you find and if I can assist you further.
Regards, Kyle (Baratza)
President, Baratza LLC
http://www.baratza.com
kyle anderson
Postby Rostik_KIEV on Mon Jan 18, 2010 4:17 pm
To increase grinding size.
Probably, at you light grain... It is firmer.
Rostik_KIEV
Postby nau on Mon Jan 18, 2010 11:52 pm
kyle anderson
Hi Kyle, thanks for reply
yes you are right, it's Mahlkoenig Vario (i guess moderator had edited topic name), because we had here 220v. I had check how burr is turning and it's going clockwise (not counterclockwise). Is it reversed?
I'm located in Kazakhstan, Almaty and i think there is no dealer here.
Rostik_KIEV, any grinder should make some grounds at any regulator position. Mine does not do any at any position.
nau
Postby kyle anderson on Fri Jan 29, 2010 12:58 pm
Hi Anton,
I am sorry for my long delay in getting back to you. Your grinder is turning in the WRONG direction. It should be rotating COUNTER clockwise. The fix for this is very simple and quick to do. It requires only that the plug for the motor wires be reversed and reconnected. The plug is a simple 2-pin connector that slips onto the power board (inside the grinder). The only tools required to do this fix is a Phillips screwdriver and about 5 minutes of your time. Please email me with your contact info and I will send you instructions for getting inside the grinder.
Regards,
Kyle
kyle anderson
Postby nau on Sat Jan 30, 2010 5:36 am
Hi Kyle!
thank you so much for help and this awesome guide! I'm done it today and finally see grounded coffee :lol:
it was so simple and took only few minutes. Now it grinds like a tank, amazing!
Grinder is perfect! Thank you very very much!
nau
Postby espressme on Sat Jan 30, 2010 10:15 am
And, folks, this is customer service! Thank you Kyle!
-Richard
richard penney LMWDP #090,
espressme
Postby da gino on Sat Jan 30, 2010 10:59 am
Agreed especially since it isn't even a Baratza grinder! I have a special loyalty to companies that back up products they didn't sell and didn't make any money on.
da gino
Postby nau on Sun Jan 31, 2010 12:44 pm
Fully agreed. If this is customer service it is best experience i ever had.
Baratza is the best!
Kyle thank you again!
nau
Return to Grinders
