New Baratza grinder: the Sette Series - Page 69
- Clint Orchuk
Our Sette 270 just arrived tonight. Wills start to play with it tomorrow. 270W hopefully later in August
- Compass Coffee
I received UPS notification something had shipped from Baratza but nada from Baratza. Will know when package arrives today whether 270, 270W or both.
Mike McGinness
- johnny4lsu
Got mine today. Any idea how to calibrate it to use for brew? It's calibrated for espresso at the moment and barely gets coarse enough for drip.
- Calendar
Are these purchased grinders people are getting? Or are they testing/evaluation/review units?
- johnny4lsu
Resellers got the option to purchase early units. Not sure if they will be changed from here.
- Boldjava
Johnny, SCG has a pdf: https://www.seattlecoffeegear.com/asset ... -guide.pdfjohnny4lsu wrote:Got mine today. Any idea how to calibrate it to use for brew? It's calibrated for espresso at the moment and barely gets coarse enough for drip.
LMWDP #339
LMWDP #339
- johnny4lsu
Thanks. That actually came with the grinder. Even at the most coarse setting its still way too fine.
- Clint Orchuk
Ours is one of the units offered to resellers. 270W is supposed to ship August 9. They look amazing. Got into a marathon bakefest this morning (pastries, not coffee) and still haven't had a chance to try it out.
Even after making all the adjustments and removing washers? What type of brew is it for?johnny4lsu wrote:Thanks. That actually came with the grinder. Even at the most coarse setting its still way too fine.
- Compass Coffee
Received my 270 last afternoon yesterday. TIP: I believe the current quick start directions for espresso of 5 -E were for before they recalibrated finer. First ground (Delirium) with 10 seconds default at default 5 - E and weighed output. Too much. Reduced time to 8.5 seconds started again with motor stall after about 4 sec (counter kept going). Opened up grind and stayed stalled. Required dropping burr to get going again. Tried again stalled again. Said to heck with it and went home to play a bit more with new Slayer.
This morning dropped burr and cleared again and opened up to 9 - E. Too coarse but not by that much. Ended up dialing in 7 - E'ish 4.4 seconds ~19g for shot on Cynrca 12 sec pre-infusion to 9 bar until 35 sec back to line pressure to 40sec end same as pulling via M7D. Quite good shot. Took out the Delirium and replaced with Colombia that was in the Major and ran it for the day no problems. (Which isn't saying much at the slow Roastery bar, maybe 6 more grind and pulls of the Colo'!) Busy roasting and didn't do any direct head to head shot tasting...
Cautiously optimistic. Of course zero illusions it will have any kind of robustness like a commercial grinder.
Oh the PF forks and retainer on the 270W will have to be very different or won't work with 58mm nekkid...attempting hands free with 270 doesn't work with PF.
Mike McGinness
