Nemox (Isomac/Lelit/Quamar) grinder motor reassembly
Hi all,
I recently took my Nemox grinder apart for a clean and cause I like to tinker. In putting it back together there were 2 straight metal washers, 1 bent/arched metal washer, and 3 or 4 dark red/maroon plastic-y washers on the top and bottom of the motor shaft that runs into the gear that turns the bottom burr.
My issue is that I didn't take a photo beforehand and can't be certain that I've put these back in the right place! I want to make sure I get it right so I don't do the grinder any damage.
If someone has one of these grinders, would you be able to take the motor out and take a photo of the bottom of the motor shaft as well as the top where it goes into the gear assembly, clearly showing the assembly of those washers for me?
The photo below is of the rough areas I'm taking about - I just haven't been able to find any photos online that are clear enough to tell.
Many thanks!!
Many thanks!!
Anyone with this grinder able to take some pics for me?
Thanks!!
Thanks!!
