So I had to swap switches on a few grinders, and the Major was the temporary donor. I was clearly NOT thinking and took no pictures of the wiring setup for the timer switch before the swap. I've searched around for hours and have come up with zero as to what wires go where. And from the looks of it, I think my Major is wired differently than what I've seen on the 'net. And I am clearly electrically challenged. HELP!
Thanks, Tom.
2 brown wires for switch, the other 2 taped browns are from the microswitch. The blue wire is another for the switch.
the new switch, same as the previous one.
The yellow wire from the motor.
This is my wiring configuration.
